dhalliday
May 11, 2016Initiate
In site to site VPN I need all internet traffic to exit site A.
I have 2 sites connected via a pair of SRX5308's A = 192.168.1.0/24 WAN IP = 1.1.1.1 B = 192.168.2.0/24 WAN IP = 2.2.2.2 Now what I need to do is have all traffic from B go to site A ...
- May 12, 2016
After some more thought and testing I have come up with a workable solution to my own problem. I will share it here in case it may help others.
1) Use the wizard on both ends to set up a normal VPN that connects the two lan segments 192.168.1.0 and 192.168.2.0
2) Go to VPN-VPN Policy on the remote site router192.168.2.1 and hit Edit
a) Uncheck Netbios
b) Select "Any" from the Remote IP dropdown.
c) Apply the change
3) Go to VPN->VPN Policy on the head end site (192.168.1.1) and hit Edit
a) Uncheck Netbios
b) Select "Any" from the Local IP dropdown
c) Apply the change
Now all traffic wil go down the VPN tunnel and exit to the internet at the head end site. Hope this helps other with the same issue.
dhalliday
May 12, 2016Initiate
a) Uncheck Netbios
c) Apply the change
a) Uncheck Netbios
c) Apply the change
- JohnRoMay 13, 2016NETGEAR Employee Retired
Hello dhalliday,
Welcome to the community!
Thank you for sharing your solution, I am sure this will help other community members if they come up with the same issue.
Cheers,
