laque32
Jan 02, 2020Aspirant
Insight Tap VPN getting 169.x.x.x IP address
One computer can connect to the VPN fine. I use another laptop with another user ID with the same settings and it won't connect properly. I can connect to the Internet just fine on the VPN, but not...
JohnC_V
Jan 03, 2020NETGEAR Employee Retired
Hi laque32,
Welcome to our community! :)
169.x.x.x address is an auto-assigned IP address. May I know where are you seeing this IP? Your PC should connect properly to the internet first before connecting it to the VPN.
John
NETGEAR Community Team
laque32
Jan 03, 2020Aspirant
I see it for the IP address on the insight tap VPN after connecting to the VPN. It shows connected via VPN app...but that's not true because of the IP address.
- laque32Jan 03, 2020Aspirant
Ok, I found out what the issue was. It was the BR500 Router. When I got home and logged on the network. I was able to ping my router but not login to it by IP. I was able to login by going to routerlogin.net. So that was strange within itself. After leaving it unplugged for 2 minutes and turning it back on. I was able to login via IP and tested my VPN and everything is working and back to normal. I never thought about reseting the VPN router since all of my other devices were working fine without issues. However, I am glad everything is working!
