vpnbeginner
Sep 01, 2015Aspirant
IPSEC Site to Site FVS336 to FVS318
Hi Netgear Community,
I want to set up a Site to Site connection between FVS336 and FVS318 at our costumer s office. At there site the FVS318 is behind a firewall. They forward ESP, AH and Port 500 UDP to the device. Is there any possibility to check the ports (like telnet)? Both routers were configured by wizard. I just changed the mode to aggressive and the SA lifetime to 86400. The local subnets are 10.9.8.x and 192.168.4.x.
Thank you a lot for any suggestions.
1 Reply
- aditMentor
You want the VPN router to get the public IP on it's WAN. If it is DSL service, you need to place the ISP router/modem in Bridge Mode.
If that is not possible, your only other option is to place the VPN router in the DMZ.
You should use Main Mode - Both Directions in almost all cases with a Site to Site VPN.
SA Lifetimes, 3600 if either WAN IP Address is Dynamic, 86400 if BOTH WAN IP Addresses are Static.
