tsuihugh
Jun 05, 2022Follower
IPSec site to site VPN BR200 Access devices
site to site was configure wth ipsec vpn between br200 ping to other network go well but the pc is denied access to other networks i can not connect to ther server service(http, samba,.. etc) of ...
gtoharpoon
Jun 13, 2022Aspirant
I have a Br200 with the same problem. The IPsec VPN established and the status is 'green'.
I can ping the remote devices from both sides. However, I cannot access the services from both sides. No matter I set the static route or traffic rule.
What should I do of the correct router setting?
Thanks.
DaneA
Nov 10, 2022NETGEAR Employee Retired
Since the IPsec VPN established wherein it shows that the status is 'green' and you can ping the remote devices from both sides, I think there is no problem on the VPN settings of the BR200. Kindly check the permissions set on the devices that you wanted to access.
Also, if ever you are not yet aware, kindly read the article below:
Security Advisory for Multiple Security Vulnerabilities on BR200 and BR500, PSV-2021-0286
DaneA
NETGEAR Community Team
