BGy
Nov 28, 2016Tutor
IPSec VPN Connection lost
My client is a Netgear Prosafe VPN Client Lite 6.4 (Windows 10 Prof x64) and I connect to a FVS336Gv3 firewall in the office.I can connect usually without any problem, I can open a Windows Remote Des...
Dan_Z
Nov 28, 2016NETGEAR Expert
Hi,
Welcome to the community!
Please make sure the Netgear Prosafe VPN Client Lite and FVS336Gv3 is lastest version (VPN Lite v6.40.004,FVS336Gv3 4.3.4-2).
You may download lastest version from netgear download center.
IPSec VPN connection lost may be due to network reasons,so suggest check the network.
Thanks.
- BGyDec 02, 2016Tutor
Hi Dan_Z,
I use latest versions as you listed. Previously I used L2TP/Ipsec and I found it's very stable, my connection survived the whole working day, but it's throughput is poor.
Because the planned higher number of VPN users we'd like to use IPsec VPN which offer higher throughput.
With FVS336Gv3 we got one license of VPN Client, currently I make tests with it, but before I recommend to management buying licenses for other employees, I should find a sollution to make it stable.
Would you give me an advice, how to catch network problem you mentioned or how to get a detailed info about the problem?
BR
- Dan_ZDec 05, 2016NETGEAR Expert
Hi BGy,
The data of IPSec VPN throughput on FVS336Gv3,can refer to:http://www.downloads.netgear.com/files/GDC/datasheet/en/FVS318G-FVS318N-FVS336G-SRX5308.pdf
Thanks,
Dan
- BGyDec 05, 2016Tutor
Hi Dan_Z,
thank you for the throughput information. But please help me how to diagnose/fix my disconnection problem! I'd like to use IPsec instead L2TP.
Thanks,
Gyula
