BGy
Nov 28, 2016Tutor
IPSec VPN Connection lost
My client is a Netgear Prosafe VPN Client Lite 6.4 (Windows 10 Prof x64) and I connect to a FVS336Gv3 firewall in the office.I can connect usually without any problem, I can open a Windows Remote Des...
BGy
Dec 02, 2016Tutor
Hi Dan_Z,
I use latest versions as you listed. Previously I used L2TP/Ipsec and I found it's very stable, my connection survived the whole working day, but it's throughput is poor.
Because the planned higher number of VPN users we'd like to use IPsec VPN which offer higher throughput.
With FVS336Gv3 we got one license of VPN Client, currently I make tests with it, but before I recommend to management buying licenses for other employees, I should find a sollution to make it stable.
Would you give me an advice, how to catch network problem you mentioned or how to get a detailed info about the problem?
BR
Dan_Z
Dec 05, 2016NETGEAR Expert
Hi BGy,
The data of IPSec VPN throughput on FVS336Gv3,can refer to:
http://www.downloads.netgear.com/files/GDC/datasheet/en/FVS318G-FVS318N-FVS336G-SRX5308.pdf
Thanks,
Dan
- BGyDec 05, 2016Tutor
Hi Dan_Z,
thank you for the throughput information. But please help me how to diagnose/fix my disconnection problem! I'd like to use IPsec instead L2TP.
Thanks,
Gyula
- Dan_ZDec 06, 2016NETGEAR Expert
Hi BGy,
I don't know your specific network environment, so can't give you the advice.
Here is some diagnostic tool on FVS336Gv3's page "Monitoring->Disagnostics",maybe can help you.Thanks,
Dan
- BGyDec 07, 2016Tutor
Hi Dan_Z,
please explain why your conclusion is a network problem. Just now I tested it again. I used a ping tool to check remote LAN accessibility. It shows that connection lost at 10:05:00:
[2016-12-7 10:05:26]Reply from 192.168.11.10: Request timed out. [2016-12-7 10:05:22]Reply from 192.168.11.10: Request timed out. [2016-12-7 10:05:18]Reply from 192.168.11.10: Request timed out. [2016-12-7 10:05:14]Reply from 192.168.11.10: Request timed out. [2016-12-7 10:05:10]Reply from 192.168.11.10: Request timed out. [2016-12-7 10:05:06]Reply from 192.168.11.10: Request timed out. [2016-12-7 10:05:00]Reply from 192.168.11.10: bytes = 64 time = 13ms TTL = 255 [2016-12-7 10:04:58]Reply from 192.168.11.10: bytes = 64 time = 12ms TTL = 255 [2016-12-7 10:04:56]Reply from 192.168.11.10: bytes = 64 time = 14ms TTL = 255 [2016-12-7 10:04:54]Reply from 192.168.11.10: bytes = 64 time = 14ms TTL = 255 [2016-12-7 10:04:52]Reply from 192.168.11.10: bytes = 64 time = 15ms TTL = 255 [2016-12-7 10:04:50]Reply from 192.168.11.10: bytes = 64 time = 12ms TTL = 255 [2016-12-7 10:04:48]Reply from 192.168.11.10: bytes = 64 time = 15ms TTL = 255
The appropriate part of VPN Client log:20161207 10:03:39:175 Default (SA CTC-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE 20161207 10:03:39:222 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK 20161207 10:04:09:326 Default (SA CTC-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE 20161207 10:04:09:370 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK 20161207 10:04:36:498 Default (SA CTC-P1) SEND phase 1 Main Mode [SA] [VID] [VID] [VID] [VID] [VID] 20161207 10:04:36:608 Default (SA CTC-P1) RECV phase 1 Main Mode [SA] [VID] [VID] [VID] 20161207 10:04:36:611 Default (SA CTC-P1) SEND phase 1 Main Mode [KEY_EXCH] [NONCE] [NAT_D] [NAT_D] 20161207 10:04:36:837 Default (SA CTC-P1) RECV phase 1 Main Mode [KEY_EXCH] [NONCE] [NAT_D] [NAT_D] [VID] 20161207 10:04:36:839 Default (SA CTC-P1) SEND phase 1 Main Mode [HASH] [ID] 20161207 10:04:37:055 Default (SA CTC-P1) RECV phase 1 Main Mode [HASH] [ID] 20161207 10:04:37:056 Default phase 1 done: initiator id local.com, responder id xxxxxxxxxxxxxx.dnsalias.com 20161207 10:04:37:056 Default (SA CTC-P1) renewal in 3412 seconds (11:01:29) 20161207 10:04:37:074 Default (SA CTC-P1) RECV Transaction Mode [HASH] [ATTRIBUTE] 20161207 10:04:37:075 Default (SA CTC-P1) SEND Transaction Mode [HASH] [ATTRIBUTE] 20161207 10:05:02:185 Default (SA CTC-ctc-P2) SEND phase 2 Quick Mode [HASH] [SA] [NONCE] [ID] [ID] 20161207 10:05:02:398 Default (SA CTC-ctc-P2) RECV phase 2 Quick Mode [HASH] [SA] [NONCE] [ID] [ID] 20161207 10:05:02:398 Default (SA CTC-ctc-P2) SEND phase 2 Quick Mode [HASH] 20161207 10:05:02:399 Default (SA CTC-ctc-P2) renewal in 1092 seconds (10:23:14) 20161207 10:05:02:399 Default [VirtualItf] ConfigureVirtualItf: Physical IP Address specified in configuration for CTC-P1. 20161207 10:05:03:459 Default (SA CTC-ctc-P2) [VirtualItf] Virtual Interface properly configured for instance 2 and ItfIndex 8. 20161207 10:05:06:461 Default (SA CTC-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE 20161207 10:05:06:500 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK 20161207 10:05:13:694 TIKEV1_OLDTGBIKE IKEv1 traffic: no response from 192.168.11.10 (error 11010) 20161207 10:05:22:628 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE 20161207 10:05:22:628 Default (SA CTC-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK 20161207 10:05:24:194 TIKEV1_OLDTGBIKE IKEv1 traffic: no response from 192.168.11.10 (error 11010) 20161207 10:05:27:677 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE 20161207 10:05:27:678 Default (SA CTC-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK 20161207 10:05:32:736 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE 20161207 10:05:32:736 Default (SA CTC-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK 20161207 10:05:34:694 TIKEV1_OLDTGBIKE IKEv1 traffic: no response from 192.168.11.10 (error 11010) 20161207 10:05:37:786 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE 20161207 10:05:37:787 Default (SA CTC-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK 20161207 10:05:42:839 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE 20161207 10:05:42:840 Default (SA CTC-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK 20161207 10:05:45:194 TIKEV1_OLDTGBIKE IKEv1 traffic: no response from 192.168.11.10 (error 11010) 20161207 10:05:47:890 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE 20161207 10:05:47:890 Default (SA CTC-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK 20161207 10:05:52:946 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE
As I see after 10:05:00 there are successful DPDs.
But after 10:05:00 I'm still able to connect using L2TP without problem! If it's a network problem why can I connect L2TP, why only IPsec fails? If connection fails why VPN client can't reconnect? If it's a network problem then shouldn't I experience this problem in random intervals? Now it's happens about after an hour (50..70min), never outside of this time frame.
Thanks,
Gyula
