BGy
Nov 28, 2016Tutor
IPSec VPN Connection lost
My client is a Netgear Prosafe VPN Client Lite 6.4 (Windows 10 Prof x64) and I connect to a FVS336Gv3 firewall in the office.I can connect usually without any problem, I can open a Windows Remote Des...
Dan_Z
Dec 05, 2016NETGEAR Expert
Hi BGy,
The data of IPSec VPN throughput on FVS336Gv3,can refer to:
http://www.downloads.netgear.com/files/GDC/datasheet/en/FVS318G-FVS318N-FVS336G-SRX5308.pdf
Thanks,
Dan
BGy
Dec 05, 2016Tutor
Hi Dan_Z,
thank you for the throughput information. But please help me how to diagnose/fix my disconnection problem! I'd like to use IPsec instead L2TP.
Thanks,
Gyula
- Dan_ZDec 07, 2016NETGEAR Expert
Hi BGy,
I don't know your specific network environment, so can't give you the advice.
Here is some diagnostic tool on FVS336Gv3's page "Monitoring->Disagnostics",maybe can help you.Thanks,
Dan
- BGyDec 07, 2016Tutor
Hi Dan_Z,
please explain why your conclusion is a network problem. Just now I tested it again. I used a ping tool to check remote LAN accessibility. It shows that connection lost at 10:05:00:
[2016-12-7 10:05:26]Reply from 192.168.11.10: Request timed out. [2016-12-7 10:05:22]Reply from 192.168.11.10: Request timed out. [2016-12-7 10:05:18]Reply from 192.168.11.10: Request timed out. [2016-12-7 10:05:14]Reply from 192.168.11.10: Request timed out. [2016-12-7 10:05:10]Reply from 192.168.11.10: Request timed out. [2016-12-7 10:05:06]Reply from 192.168.11.10: Request timed out. [2016-12-7 10:05:00]Reply from 192.168.11.10: bytes = 64 time = 13ms TTL = 255 [2016-12-7 10:04:58]Reply from 192.168.11.10: bytes = 64 time = 12ms TTL = 255 [2016-12-7 10:04:56]Reply from 192.168.11.10: bytes = 64 time = 14ms TTL = 255 [2016-12-7 10:04:54]Reply from 192.168.11.10: bytes = 64 time = 14ms TTL = 255 [2016-12-7 10:04:52]Reply from 192.168.11.10: bytes = 64 time = 15ms TTL = 255 [2016-12-7 10:04:50]Reply from 192.168.11.10: bytes = 64 time = 12ms TTL = 255 [2016-12-7 10:04:48]Reply from 192.168.11.10: bytes = 64 time = 15ms TTL = 255
The appropriate part of VPN Client log:20161207 10:03:39:175 Default (SA CTC-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE 20161207 10:03:39:222 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK 20161207 10:04:09:326 Default (SA CTC-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE 20161207 10:04:09:370 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK 20161207 10:04:36:498 Default (SA CTC-P1) SEND phase 1 Main Mode [SA] [VID] [VID] [VID] [VID] [VID] 20161207 10:04:36:608 Default (SA CTC-P1) RECV phase 1 Main Mode [SA] [VID] [VID] [VID] 20161207 10:04:36:611 Default (SA CTC-P1) SEND phase 1 Main Mode [KEY_EXCH] [NONCE] [NAT_D] [NAT_D] 20161207 10:04:36:837 Default (SA CTC-P1) RECV phase 1 Main Mode [KEY_EXCH] [NONCE] [NAT_D] [NAT_D] [VID] 20161207 10:04:36:839 Default (SA CTC-P1) SEND phase 1 Main Mode [HASH] [ID] 20161207 10:04:37:055 Default (SA CTC-P1) RECV phase 1 Main Mode [HASH] [ID] 20161207 10:04:37:056 Default phase 1 done: initiator id local.com, responder id xxxxxxxxxxxxxx.dnsalias.com 20161207 10:04:37:056 Default (SA CTC-P1) renewal in 3412 seconds (11:01:29) 20161207 10:04:37:074 Default (SA CTC-P1) RECV Transaction Mode [HASH] [ATTRIBUTE] 20161207 10:04:37:075 Default (SA CTC-P1) SEND Transaction Mode [HASH] [ATTRIBUTE] 20161207 10:05:02:185 Default (SA CTC-ctc-P2) SEND phase 2 Quick Mode [HASH] [SA] [NONCE] [ID] [ID] 20161207 10:05:02:398 Default (SA CTC-ctc-P2) RECV phase 2 Quick Mode [HASH] [SA] [NONCE] [ID] [ID] 20161207 10:05:02:398 Default (SA CTC-ctc-P2) SEND phase 2 Quick Mode [HASH] 20161207 10:05:02:399 Default (SA CTC-ctc-P2) renewal in 1092 seconds (10:23:14) 20161207 10:05:02:399 Default [VirtualItf] ConfigureVirtualItf: Physical IP Address specified in configuration for CTC-P1. 20161207 10:05:03:459 Default (SA CTC-ctc-P2) [VirtualItf] Virtual Interface properly configured for instance 2 and ItfIndex 8. 20161207 10:05:06:461 Default (SA CTC-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE 20161207 10:05:06:500 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK 20161207 10:05:13:694 TIKEV1_OLDTGBIKE IKEv1 traffic: no response from 192.168.11.10 (error 11010) 20161207 10:05:22:628 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE 20161207 10:05:22:628 Default (SA CTC-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK 20161207 10:05:24:194 TIKEV1_OLDTGBIKE IKEv1 traffic: no response from 192.168.11.10 (error 11010) 20161207 10:05:27:677 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE 20161207 10:05:27:678 Default (SA CTC-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK 20161207 10:05:32:736 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE 20161207 10:05:32:736 Default (SA CTC-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK 20161207 10:05:34:694 TIKEV1_OLDTGBIKE IKEv1 traffic: no response from 192.168.11.10 (error 11010) 20161207 10:05:37:786 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE 20161207 10:05:37:787 Default (SA CTC-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK 20161207 10:05:42:839 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE 20161207 10:05:42:840 Default (SA CTC-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK 20161207 10:05:45:194 TIKEV1_OLDTGBIKE IKEv1 traffic: no response from 192.168.11.10 (error 11010) 20161207 10:05:47:890 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE 20161207 10:05:47:890 Default (SA CTC-P1) SEND Informational [HASH] [NOTIFY] type DPD_R_U_THERE_ACK 20161207 10:05:52:946 Default (SA CTC-P1) RECV Informational [HASH] [NOTIFY] type DPD_R_U_THERE
As I see after 10:05:00 there are successful DPDs.
But after 10:05:00 I'm still able to connect using L2TP without problem! If it's a network problem why can I connect L2TP, why only IPsec fails? If connection fails why VPN client can't reconnect? If it's a network problem then shouldn't I experience this problem in random intervals? Now it's happens about after an hour (50..70min), never outside of this time frame.
Thanks,
Gyula
I found something something. In my prevoius comment the time of loosing connection was 10:05:00. And at the beginning of the log I found this:
20161207 09:13:06:804 Default (SA CTC-ctc-P2) is opening. 20161207 09:13:07:847 Default (SA CTC-P1) SEND phase 1 Main Mode [SA] [VID] [VID] [VID] [VID] [VID] 20161207 09:13:07:964 Default (SA CTC-P1) RECV phase 1 Main Mode [SA] [VID] [VID] [VID] 20161207 09:13:07:974 Default (SA CTC-P1) SEND phase 1 Main Mode [KEY_EXCH] [NONCE] [NAT_D] [NAT_D] 20161207 09:13:08:201 Default (SA CTC-P1) RECV phase 1 Main Mode [KEY_EXCH] [NONCE] [NAT_D] [NAT_D] [VID] 20161207 09:13:08:210 Default (SA CTC-P1) SEND phase 1 Main Mode [HASH] [ID] [NOTIFY] 20161207 09:13:08:482 Default (SA CTC-P1) RECV phase 1 Main Mode [HASH] [ID] 20161207 09:13:08:482 Default phase 1 done: initiator id local.com, responder id xxxxxxxxxxx.dnsalias.com 20161207 09:13:08:483 Default (SA CTC-P1) renewal in 3088 seconds (10:04:36)
"renewal in 3088 seconds (10:04:36)" The renewal time is the exact time of loosing connection. Something goes wrong about renewal...
Thanks,
Gyula
