praveenkmr
Dec 01, 2015Aspirant
Load Balancing in dual WAN: WAN1 for local internet access & WAN2 for RDP connection
HI, I am trying to configure the firewall in Load Balancing mode (Dual WAN). WAN1 to be used for local internet access (emails, browsing) and WAN to be dedicated for Remote Desktop connecti...
BrianL2
Dec 01, 2015NETGEAR Employee Retired
Hi praveenkmr,
Can you confirm if both WAN interfaces are Up under the Router Status in the Monitoring tab?
Kind regards,
BrianL
NETGEAR Community Team
- praveenkmrDec 01, 2015Aspirant
Hi Brian,
The status of both the WANs are UP and Connected.
- DaneADec 02, 2015NETGEAR Employee Retired
Hi praveenkmr,
Here are my follow-up questions below:
a. What is the model of the NETGEAR firewall you are using?
b. What is the current firmware version of the NETGEAR firewall you are using?
c. How did you know that the users are unable to login via RDP on WAN2 port? Kindly post a screenshot of it.
d. Just to isolate the problem, have you tried to configure protocol binding on WAN1 with RDP then WAN2 with HTTP & HTTPS? Kindly try it and observe what will be the results.
I look forward to your response.
DaneA
