morrisonkena
Sep 22, 2015Aspirant
Mac OS X Yosemite VPN setup
I have a Netgear FVS336G3 VPN Firewall set up as my home internet gateway, patched to current version. While my ISP does not issue a fixed IP address, the address issued is static until the firewall ...
DaneA
Sep 23, 2015NETGEAR Employee Retired
Hi morrisonkena,
For client-to-box IPSec VPN setup using MAC, let me share these links below as references:
Mac OS X VPN Client install with ProSAFE VPN Firewall/Router
http://oemden.com/ip-securitas-netgear-fvs336g-settings/
http://www.kossboss.com/netgear---mac-iphone-ipsec-vpn-client-setup
http://www.vpntracker.com/us/vendor/6/netgear-mac-vpn-client.html
Also, kindly read this forum link from Apple Support Communities below:
https://discussions.apple.com/thread/1351175?tstart=0
Hope it helps. Welcome to the community! :smileyhappy:
DaneA
NETGEAR Community Team
- morrisonkenaSep 23, 2015Aspirant
Thanks DaneA! I'll check out the links and confirm my results.
- Ken
- morrisonkenaSep 27, 2015Aspirant
Thanks DaneA. I am writing to post an update, and so you-all will know I am still working toward a solution. I also believe my interest in Apple connectivity to Netgear's VPN gateway product is of general interest to other Apple users, so it would be great to nail a solution and publish it.
Over the last few days I have tried without success to connect using the instructions found from your kossboss.com link. I have tried both on my iMac (OS x Yosemite) and my iPad (iOS 9.x). In both cases I get a "server not responding" error on the client device. On my VPN log I see no connection attempt.
These are some constraints I am working with:
* My preference, and first attempts, are to use Apple's built-in VPN client, accessed from Mac through System Preferences -> Network, then selection to set up a VPN interface, and on iOS accessed using the Settings app -> General -> VPN.
>> If I continue to be unsuccessful I will try a third-party VPN client, such as vpntracker.
* Like most home users I have an ISP that only provides a NAT assigned IPv4 address, though this address stays stable unless I reboot the NetGear VPN gateway, which I rarely do.
>> My ISP does provide a "permanent" IPv6 address, so I could try to switch to IPv6 on the VPN gateway and client, but am concerned about complications (IPv6 DNS, etc.)
* I have selected to use a shared secret for client/server connection, also using an account login and password set up on the VPN gateway so my client can log in and get a DHCP assigned local LAN IP address.
I am, of course, open to any and all ideas from all of you out there in the Netgear Community!
- Ken (morrisonkena)
- Retired_MemberSep 28, 2015
I literally just got it working in Windows10. Let me test on a Yosemite Mac. This may be an option for you.
** On a side note: Netgear could really use a good Tech Writer for their documentation.
