transistor's avatar
transistor
Management Software for my 25 FVS338 routers
I have about 25 ProSafe FVS338 routers spread around my factory firewalling machines from the WAN. Is there any network management software available for these (similar to NMS200) so I can rapidly compare configurations, firmware, etc.?
Failing that, has anyone seen any good scripts to grab the config backup files from the routers and parse them out - into Excel for example?
Any other cool ideas?
Many thanks.
  • Look solar winds. They are pretty cool company
    Or so spiceworks got some cool management but any snmp app should work for you.
  • Thanks for that. I've been using the routers for years but never looked into SNMP so I didn't realise what it is for. Most of the applications seem to be logging assets including computers, etc., and monitoring traffic. I just want an easy way of examining, and maybe editing, the firewall configurations of my routers.
    Anyone seen a simple app for this?
  • telnet is there to access the router for config or console capable router to config routers.
  • I'm aware of that, thanks, hence my request for scripts.
    I'll play around and see how I get on.
    Thanks.
ProSupport for Business
