ridgedale
Mar 15, 2018Aspirant
Multiple Firewalls Configuration
I am trying to setup a multiple router configuration using an FVS2318N (firmware version: v4.3.5-3) and FVS318v3 (firmware version: v3.0_28) Firewalls to create two distinct networks both able to acc...
- Mar 22, 2018
The IP and DNS server addresses were all 0.0.0.0.
Switching port 5 on the FVS318N back to the default VLAN assignment allowed my laptop to connect via ethernet to the Internet when connected to that port.
I realised that with DHCP disabled for the secondary VLAN the FVS318v3 was not getting a WAN IP address any DNS information.So, you are actually doing a port-based VLAN and the DHCP is disabled that is why the FVS318v3 is not receiving any IP from port 5. If port-based VLAN is being used, only the said VLAN address will passthrough. Default is same as Trunking in "Default VLAN" configuration.
What I also realised is all/any IP addresses assigned to VLANs on the FVS318N must be unique IP ranges and the IP ranges for any router attached to one/any of the FVS318N configured VLAN ports must also be a configured with separate unique IP range.
Well, it depends if you wanted to separate each port of the FVS318N.
Then for any router connecting to any of the VLAN ports (taking Port 5 as an example) the WAN and LAN should be configured as follows:
WAN configuration:
Does Your Internet Connection Require A Login? No | Internet IP Address : Get Dynamically From ISP (obtains the WAN IP Address : 192.168.5.2 & Gateway IP Address : 192.168.5.1) | Domain Name Server (DNS) Address : Get Automatically From ISP
LAN configuration:
LAN TCP/IP Setup : 192.168.15.1 | Subnet Mask : 255.255.255.0 | LAN IP Address Management : Use Router as DHCP Server (or 192.168.15.1) | DHCP Server Info - Starting IP Address : 192.168.15.201 Ending IP Address : 192.168.15.220 | Use These DNS Servers - Primary DNS Server : 192.168.15.1
Currently the FVS318v3 has following settings also configured under LAN IP Setup:
RIP Direction : None
RIP Version : Disabled
MTU Size - Custom : 1492
Are those settings correct? Do they need to be changed at all?
Have I understood correctly? If so, do the same principles apply to configure a 24-port VLAN enabled smart switch to, for example, create three sub-VLANs connected to Port 3 of the FVS318N?Yes, everything seems to be correct. If you will be connecting a VLAN switch, then the uplink port of the switch should be set to T and should be connected to a trunk port of the router.
e.g.
FVS318v3 has 3 VLANS.
VLAN 1 - 192.168.10.x
VLAN 2 - 192.168.20.x
VLAN 3 - 192.168.30.x
All VLANs are DHCP Enabled
Port 1 - Default - All VLANs can passthrough as it is set to Trunk
Port 2 - VLAN 2 - Only VLAN 2 will passthrough as it is set to port-based
Port 3 - VLAN 3 - Only VLAN 3 will passthrough as it is set to port-based
On this case, you can connect the switch to Port 1 of the router and set the uplink port of the switch as T or Tagged / Trunk. Just make sure that you also created the 3 VLANs in the switch. If there's any confusion just let me know.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ridgedale
Mar 19, 2018Aspirant
Hi JohnCarloV,
Thank you for your reply.
I've checked the Enable DNS Proxy setting for the VLAN and rebooted the computer, but there was no change. I still cannot access the Internet from any device connected to the secondary FVS318v3 firewall. I've also tried switching the network cable connected to the primary FVS318N firewall from the Internet port to one of the LAN ports. That did not work either.
Is there anything else that needs to be changed?
Kind Regards
ridgedale
JohnC_V
Mar 19, 2018NETGEAR Employee Retired
Just to verify, Did you hit apply right after putting a check mark on the enable DNS proxy? Kindly bypass the FVS318v3 and connect it directly to the modem. May you be able to attach a screenshot of your current network setup?
