Makookam
Jul 09, 2018Aspirant
My Firewall limited download/upload to 60/60 Mbps without my interference
Hello all,
I have a problem with my broadband speed. I plug cable directly to router - I reach 1Gbps/100Mbps.
If I plug cable to firewall I reach 60/60Mbps.
Few days ago everything was OK. I did not change anything with my firewall.
Firewall: FVS318N
Firmware Version: 4.3.5-3
Left LED - blink, right LED - green.
Reboot is not help.
What should I do now?
- JohnC_VNETGEAR Employee Retired
Hi Makookam,
Welcome to our community! :)
FVS318N can only handle upto 250Mbps LAN-to-WAN throughput. It is limited to that bandwidth. If you do have 1Gbps/100Mbps then it cannot be handled by the FVS318N but it will be maxed out to its limit. You may try resetting it to factory default.
Here is the reference.
- MakookamAspirant
I did reset to factory default and restore from backup. After few days problem's back again.
Now (after reboot, not restore!) FVS318N reached 600/100.
What more can I do?
