IanB-CDS's avatar
IanB-CDS
Need to reset VPN client license
Hi, I need to reset my VPN client license so that I can use it on a different laptop. Previous laptop is no longer in circulation.
  • Hi IanB-CDS,
    Welcome to the community!
    Please uninstall the client first from the previous PC before installing it and make sure that you are connected to the internet so that it will automatically updated in our database, same as resetting the license key on our end.
    If it did not work, then please send me the license key via pm.
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi IanB-CDS,
    • IanB-CDS's avatar
      IanB-CDS
      Thanks thats really helpful, it urns out that I need to trace all our current licenses to the users which will take a while. once done I will contact you again if I cannot get the necessary liceses uninstalled.
  • JohnC_V's avatar
    JohnC_V
    IanB-CDS,
    I would like to have a follow up on this thread. Please let us know if you still need further assistance and just in case that the reply would be the answer to your issue. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
