giugeo85
Feb 03, 2017Aspirant
Netgear firewall connetto to fritzbox 3270
Hi all, i try to write here, because i can't solve my problem :( today i receive my FV318G firewall i connect to fritzbox 3270; but when try to connect direcly to firewall from internet not work...
- Mar 02, 2017
Hi Giuseppe,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
giugeo85
Feb 06, 2017Aspirant
Hi JohnRo!,
Fritzbox is Connect directly ti ADSL and the firewall have an ip static with set exposed host ( in fritzbox)
Thanks
Giuseppe
Thanks
Giuseppe
JohnRo
Feb 07, 2017NETGEAR Employee Retired
Hi giugeo85,
I see, so basically the Fritz!Box is acting as your gateway. Aside from the firewall are there any other devices connected to the Fritz!box? What firmware version is currently running on the firewall by the way?
Thanks,
- giugeo85Feb 10, 2017Aspirant
Hi JohnRo,
i update the firewall at version "FVS318Gv2 Firmware Version 4.3.4-2" ( http://kb.netgear.com/31413/FVS318Gv2-Firmware-Version-4-3-4-2?cid=wmt_netgear_organic ).
Only firewall is connect to fritzbox.
Thanks
Giuseppe
