giugeo85
Feb 03, 2017Aspirant
Netgear firewall connetto to fritzbox 3270
Hi all, i try to write here, because i can't solve my problem :( today i receive my FV318G firewall i connect to fritzbox 3270; but when try to connect direcly to firewall from internet not work...
- Mar 02, 2017
Hi Giuseppe,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
JohnRo
Feb 13, 2017NETGEAR Employee Retired
Hi giugeo85,
I'm thinking you could just put the Fritz!Box on bridge mode and let the FVS318Gv2 act as the main router. When you setup DMZ did you point it to the IP address of the FVS318Gv2.
Thanks,
JohnRo
Feb 16, 2017NETGEAR Employee Retired
Hi giugeo85,
Is it possible to try my suggestion? Do you have any updates for us?
Thanks,
- JohnRoFeb 16, 2017NETGEAR Employee Retired
Hi giugeo85,
Alright, please let us know what happens.
Thanks,
- giugeo85Feb 23, 2017Aspirant
HI JohnRo,
i can confirm that i use a normal modem, work, i can connect out of office :)
Can i ask you another question? it's possible see who use the bandwitch?
Thanks
Giuseppe
- JohnRoFeb 23, 2017NETGEAR Employee Retired
Hi Giuseppe,
So just to confirm, when using a different modem you were able to connect? For the bandwidth question are you pertaining to tracking the bandwidth usage by IP adress or MAC?
Thanks,
