giugeo85
Feb 03, 2017Aspirant
Netgear firewall connetto to fritzbox 3270
Hi all, i try to write here, because i can't solve my problem :( today i receive my FV318G firewall i connect to fritzbox 3270; but when try to connect direcly to firewall from internet not work...
- Mar 02, 2017
Hi Giuseppe,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
giugeo85
Feb 16, 2017Aspirant
Hi JohnRo,
The fritzbox not have the dmz but the exposed host... but a now I think is different :(
I want try with directly modem.
In the next days I try.
Thanks
Giusepep
Thanks
Giusepep
