giugeo85
Feb 03, 2017Aspirant
Netgear firewall connetto to fritzbox 3270
Hi all, i try to write here, because i can't solve my problem :( today i receive my FV318G firewall i connect to fritzbox 3270; but when try to connect direcly to firewall from internet not work...
- Mar 02, 2017
Hi Giuseppe,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
giugeo85
Feb 23, 2017Aspirant
Hi JohnRo,
I confirm with different modem wok!!
For the bandwidth question are you pertaining to tracking the bandwidth usage by IP adress or MAC? Yes correct
Because a i found a general traffic, but not for ip.
Thanks
Giuseppe
Thanks
Giuseppe
JohnRo
Feb 27, 2017NETGEAR Employee Retired
Hi Giuseppe,
It appears that there is some sort of incompatibility with the firewall and the Fritz!box modem or could be something that needs to be changed on the previous mode. I know I have seen that specific feature (Logging bandwidth usage by MAC) but not on our firewall. I have checked our firewalls and it does not have this specific feature. What you can do to make sure that no one is hogging all of the bandwidth is to create a bandwidth profile (see page 58 of the user manual).
Thanks,
