giugeo85
Feb 03, 2017Aspirant
Netgear firewall connetto to fritzbox 3270
Hi all, i try to write here, because i can't solve my problem :( today i receive my FV318G firewall i connect to fritzbox 3270; but when try to connect direcly to firewall from internet not work...
- Mar 02, 2017
Hi Giuseppe,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
JohnRo
Feb 23, 2017NETGEAR Employee Retired
Hi Giuseppe,
So just to confirm, when using a different modem you were able to connect? For the bandwidth question are you pertaining to tracking the bandwidth usage by IP adress or MAC?
Thanks,
JohnRo
Mar 02, 2017NETGEAR Employee Retired
Hi Giuseppe,
Thanks,
