Dumbledee68's avatar
Dumbledee68
Follower
Aug 31, 2015
Netgear firewall Fvs336g issue
so I have 3 public IPs coming in my comcast business line modem. 2 LAN ports from the modem going to 1 fvs336g on 2 separate wan connections, and the 3rd going to a 2nd fvs336g for a 3rd wan connectio...
  • adit's avatar
    Sep 01, 2015
    You don't want 2 connections coming into the FVS from the same cable modem.  Just add the additional IP in the Rules you create and remove thata second cable.
    /16?  Do you understand subnetting?  /16 is the entire netblock (192.168.0.0-192.168.255.255).
    Fix your masks and it should fix your problem.
ProSupport for Business
