deroliver
Jun 03, 2019Tutor
NETGEAR Insight VPN macOS 10.14.5
I just installed my new BR500 and added a new vpn user. Unfortunately I cannot get the InsightVPNClient to run on my macbook pro running macos 10.14.5. It just crashes everytime I open the app. How c...
MrJoshW
Jun 03, 2019NETGEAR Employee Retired
Hello,
I am using OSX 10.14.2 with the latest Insight VPN client and I can connect with any issues. What version of the VPN client are you currently using? Do you have any other VPN clients installed?
schumaku
Jun 03, 2019Guru - Experienced User
MrJoshW please update your test system to macOS 10.14.5 8-)
- MrJoshWJun 04, 2019NETGEAR Employee Retired
Tested this on 10.14.5 just now and able to connect to my VPN group without any issues.
- deroliverJun 09, 2019Tutor
So I just did a clean reinstallation of macOS mojave an tried the Insight VPN client app again. The Insight VPN client app still immediately crashes when opening it. macOS gives me the following report:
Process: InsightVPNClient [571]Path: /Applications/InsightVPNClient.app/Contents/MacOS/InsightVPNClientIdentifier: com.netgear.InstantVPNVersion: 1.0 (???)Code Type: X86-64 (Native)Parent Process: ??? [1]Responsible: InsightVPNClient [571]User ID: 501Date/Time: 2019-06-09 09:37:05.177 +0200OS Version: Mac OS X 10.14.5 (18F132)Report Version: 12Bridge OS Version: 3.0 (14Y901)Anonymous UUID: 5FA60FFC-1F39-0D78-C081-5E8A494FE069Time Awake Since Boot: 190 secondsSystem Integrity Protection: enabledCrashed Thread: 0 Dispatch queue: com.apple.main-threadException Type: EXC_BAD_ACCESS (SIGSEGV)Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000008Exception Note: EXC_CORPSE_NOTIFYTermination Signal: Segmentation fault: 11Termination Reason: Namespace SIGNAL, Code 0xbTerminating Process: exc handler [571]VM Regions Near 0x8:-->__TEXT 0000000103a5d000-0000000103abc000 [ 380K] r-x/rwx SM=COW /Applications/InsightVPNClient.app/Contents/MacOS/InsightVPNClientThread 0 Crashed:: Dispatch queue: com.apple.main-thread0 libobjc.A.dylib 0x00007fff7e08804c class_conformsToProtocol + 2351 libobjc.A.dylib 0x00007fff7e087f46 -[NSObject conformsToProtocol:] + 462 com.apple.AppKit 0x00007fff516be7f1 -[NSApplication(NSTouchBarFinder) NS_touchBarProviders] + 4033 com.apple.AppKit 0x00007fff516bf8e5 _NSTouchBarFinderGatherProvidersForContainer + 644 com.apple.AppKit 0x00007fff516bef0a ___NSTouchBarFinderSetNeedsUpdateOnMain_block_invoke + 2795 com.apple.CoreFoundation 0x00007fff53991928 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 236 com.apple.CoreFoundation 0x00007fff5399185d __CFRunLoopDoObservers + 4517 com.apple.CoreFoundation 0x00007fff539338f9 CFRunLoopRunSpecific + 5148 com.apple.HIToolbox 0x00007fff52c1f96b RunCurrentEventLoopInMode + 2929 com.apple.HIToolbox 0x00007fff52c1f5ad ReceiveNextEventCommon + 35510 com.apple.HIToolbox 0x00007fff52c1f436 _BlockUntilNextEventMatchingListInModeWithFilter + 6411 com.apple.AppKit 0x00007fff50fb9987 _DPSNextEvent + 96512 com.apple.AppKit 0x00007fff50fb871f -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 136113 com.netgear.InstantVPN 0x0000000103a8435c main + 439614 libdyld.dylib 0x00007fff7f85e3d5 start + 1[...]Model: MacBookPro13,3, BootROM 256.0.0.0.0, 4 processors, Intel Core i7, 2,7 GHz, 16 GB, SMC 2.38f7Graphics: kHW_IntelHDGraphics530Item, Intel HD Graphics 530, spdisplays_builtinGraphics: kHW_AMDRadeonPro455Item, AMD Radeon Pro 455, spdisplays_pcie_device, 2 GBMemory Module: BANK 0/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C31473332443450472D30393320Memory Module: BANK 1/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C31473332443450472D30393320AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x15A), Broadcom BCM43xx 1.0 (7.77.61.2 AirPortDriverBrcmNIC-1305.8)Bluetooth: Version 6.0.12f1, 3 services, 27 devices, 1 incoming serial portsNetwork Service: Wi-Fi, AirPort, en0USB Device: USB 3.0 BusUSB Device: iBridgeThunderbolt Bus: MacBook Pro, Apple Inc., 41.1Thunderbolt Bus: MacBook Pro, Apple Inc., 41.1I do not have any issues with any other app I'm using on my mac. This is really frustrating. I'm seriously considering the return of the BR500 router, since it is definitely not working for me.
- MrJoshWJun 11, 2019NETGEAR Employee Retired
Hello,
What version of the Insight VPN client are you using? Are you able to try the previous version 1.0.0.15 to see if this version works?
