deroliver
Jun 03, 2019Tutor
NETGEAR Insight VPN macOS 10.14.5
I just installed my new BR500 and added a new vpn user. Unfortunately I cannot get the InsightVPNClient to run on my macbook pro running macos 10.14.5. It just crashes everytime I open the app. How c...
EKKO_Coleman
Jul 24, 2019Guide
I am having the same issue of it crashing on startup. I also have MBP 2016 with Mojave 10.14
My Error is also the same as posters..
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000008
Exception Note: EXC_CORPSE_NOTIFY
Works fine on Windows 10 machines, have not tested on any other OSX machines. Bought two of these BR500 specifically so I could use VPN to remote desktop on all the PC workstations I manage. Completely useless without working on my MBP
DaneA
Dec 09, 2019NETGEAR Employee Retired
deroliver / Pdabz / wowpeter / jkupe / PurelyAndy / OlivierBart / ModoL / Mluce6 / EKKO_Coleman,
In relation to the problems stated on this thread, several different complaints across a variety of Apple hardware platforms are being investigated and a fix is currently being worked on.
It would be best that you subscribe to the community thread here and wait for updates.
DaneA
NETGEAR Community Team
