centex-rj
Aug 31, 2015Aspirant
Netgear Prosafe FVS-336G (fvs336g-200eus) - Slow througput
Hi
Have a fvs336g-200eus, and LAN to WAN thoughout is about 25-30mbit. Datasheet says 350mbit? What do i do wrong? Upgraded to newest firmware, with not result. Reset to default, with no result. If i test directly to the internet, i get 90-100mbit, as my ISP promised me.
Thanks/regards
Hi centex-rj,
I have read again your initial post and since you mentioned that you have a FVS336G-200EUS, what you have is an FVS336Gv2 not an FVS336Gv3. The LAN-to-WAN Throughput of the FVS336Gv2 is 60 Mbps while the LAN-to-WAN Throughput of the FVS336Gv3 is 350 Mbps. Kindly check these links below as reference:
http://www.downloads.netgear.com/files/GDC/datasheet/en/FVS336Gv2.pdf
http://www.downloads.netgear.com/files/GDC/datasheet/en/FVS318G-FVS318N-FVS336G-SRX5308.pdf
centex-rj wrote:
A: Fiber (ISP Converted to RJ45 with a calistobox, and then through a cisco router)
B: It is connected to a Cisco ASA5505 as this router is used for administrative-net, and wifi. The Netgear router is being used as a guest wifi DHCP/Gateway, and is connected to the Cisco ASA. But if i connect a PC directly to the Cisco ASA there are full power (100mbit WAN)
C: Yes, WAN2 is same slow speed.
D: 4.3.3-5
Block TCP flood, is disabled - no increese. Also bandwith profile og content filtering are disabled as well.
Alsp tryed change it to "Classic routing" istead of "NAT" that gave about 1-2mbit, but
Based from you answers above, you have a scenario called "Double NAT" and this is why you are getting 25-30Mbps of LAN-to-WAN throughput through the FVS336Gv2. Kindly try to make the FVS336Gv2 your main firewall router not the Cisco ASA5505 then observe if you will get at least 60Mbps of LAN-to-WAN throughput through the FVS336Gv2.
DaneA
Netgear Community Team
- DaneANETGEAR Employee Retired
Hi centex-rj,
A few questions below:
a. Who is your ISP? Is it a cable or a DSL connection?
b. Is the FVS336G-200EUS connected a modem-router given by your ISP?
c. Does same problem occur if you will use the other WAN port of the FVS336G-200EUS?
d. What is the current firmware version of the FVS336G-200EUS? I know you mentioned that its the newest, I just want to know the exact firmware version of it.
I look forward to your response. Welcome to the community! :smileyhappy:
DaneA
- centex-rjAspirant
D: 4.3.3-5
Hi centex-rj,
D: 4.3.3-5
DaneA
- GuillermoPiquerAspirant
a) TELEFONICA MOVISTAR - OPTICAL FIBER - 20MB/20MB
b) YES, BECAUSE IT HAS NOT A TRANSCEPTOR TO CONVERT THE OPTICAL WIRE TO RJ45. SO ISP PROVIDES A DEVICE THEY NAMED A 'DIVA'
c) YES
d) I HAVE TESTED ALL VERSIONS YET, SINCE 3.1.1-08
Finaly we bought 2 TZ500 Sonicwall. It goes fine.
Still have the case opened with netgear support to try to recover the deveces.
Thanks
- SamirDProdigy
What type of problem did you have with bandwidth? Your bandwidth is only 20Mb and the unit can definitely handle that.
- SamirDProdigy
One thing I'd immediately try is disable the block udp/tcp flood. I've noticed that improves performance on almost all the fvs series we own.
- GuillermoPiquerAspirantWe have same problem. We only have one IP public.
We can't get out ISP device because Netgear doesn't have a fiber input.- DaneANETGEAR Employee Retired
Hi GuillermoPiquer,
I think you could possibly use an adapter-like device so that you could use your fiber connection with the FVS336Gv2 :smileyhappy:
DaneA
- versuchstierAspirantDoes "LAN-to-WAN: 60 Mbps total" mean in both directions (WAN -to -LAN)? Up and Downstream? Or just upstream LAN-to-WAN. Or is the general communication between LAN/WAN 60 Mbps total?
