centex-rj
Aug 31, 2015Aspirant
Netgear Prosafe FVS-336G (fvs336g-200eus) - Slow througput
Hi Have a fvs336g-200eus, and LAN to WAN thoughout is about 25-30mbit. Datasheet says 350mbit? What do i do wrong? Upgraded to newest firmware, with not result. Reset to default, with no result. ...
- Sep 07, 2015
Hi centex-rj,
I have read again your initial post and since you mentioned that you have a FVS336G-200EUS, what you have is an FVS336Gv2 not an FVS336Gv3. The LAN-to-WAN Throughput of the FVS336Gv2 is 60 Mbps while the LAN-to-WAN Throughput of the FVS336Gv3 is 350 Mbps. Kindly check these links below as reference:
http://www.downloads.netgear.com/files/GDC/datasheet/en/FVS336Gv2.pdf
http://www.downloads.netgear.com/files/GDC/datasheet/en/FVS318G-FVS318N-FVS336G-SRX5308.pdf
centex-rj wrote:
A: Fiber (ISP Converted to RJ45 with a calistobox, and then through a cisco router)
B: It is connected to a Cisco ASA5505 as this router is used for administrative-net, and wifi. The Netgear router is being used as a guest wifi DHCP/Gateway, and is connected to the Cisco ASA. But if i connect a PC directly to the Cisco ASA there are full power (100mbit WAN)
C: Yes, WAN2 is same slow speed.
D: 4.3.3-5
Block TCP flood, is disabled - no increese. Also bandwith profile og content filtering are disabled as well.
Alsp tryed change it to "Classic routing" istead of "NAT" that gave about 1-2mbit, but
Based from you answers above, you have a scenario called "Double NAT" and this is why you are getting 25-30Mbps of LAN-to-WAN throughput through the FVS336Gv2. Kindly try to make the FVS336Gv2 your main firewall router not the Cisco ASA5505 then observe if you will get at least 60Mbps of LAN-to-WAN throughput through the FVS336Gv2.
DaneA
Netgear Community Team
centex-rj
Sep 07, 2015Aspirant
Okay - but still. 25-30mbit is half the rated speed.
SamirD
Oct 05, 2015Prodigy
Wait, is this on wifi or via the wired lan connections? 25-30 via wifi is about right.
- centex-rjOct 05, 2015Aspirant
It was on LAN. I took it down, gave to a mad dog to play with, and bought another brand.
- SamirDOct 06, 2015Prodigy
Something odd was definitely going on. Too bad the dog got it, you could have sold it to recoup costs as it was still a current product.
- centex-rjOct 06, 2015Aspirant
Not a big fan of reselling on a product, that cant hold specs.
Like a car with 200BHP - but only in sunny conditions, and the wind in the back, and only september month, otherwise just 70BHP.. nahh
