sinieq
Apr 21, 2016Aspirant
Netgear ProSafe VPN Firewall SRXN3205 and port forwarding?
Hi, this is a long shot, but I'm pulling my hairs out at this point and might be a bit over my head as I'm new to networking :( Short story shorter, I have two servers running, one is the NAS box ...
- Apr 27, 2016
Hello sinieq,
There is a heirarchy on the Inbound Services table, this is normal. I see 4 services added using "ANY" (ANY uses any port number) you'll have to remove/disable these because of the heirarchy rule on the table, all other services will be disregarded when ANY is used. What is the port number being used by the NAS? I don't see a port defined for the NAS access. Try disabling services using "ANY" and try again adding translate to port number for the NAS.
Let us know what happens.
Thanks,
JohnRo
Apr 21, 2016NETGEAR Employee Retired
Hello sinieq,
Welcome to the community!
I'd like to get some more details for us to help you with this one. I have listed them below:
- . Does the FileMaker and the NAS use the same port number?
- What is the firmware version of the SRXN3205?
- Did you add the service "fmserver" manually by going to Security>Services?
Looking forward to your response.
Thanks,
- sinieqApr 26, 2016Aspirant
Hello, thank you for replying.
I am sorry for the late response but I wanted to get back to the office to take pictures to help with clarity and it's closed over the weekend.
This is the setup that it was before I started looking into it, with the exception that I have added the fmserver service.
To shortly summarise the Inbound Services, .39 & .111 are NAS storages, .116 and .119 related to call services, and .86 is the filemaker mac. I believe the Inbound Services are priority based in that table, as when I type my outside IP (say, 72.*.*.*) into the browser it asks me to insert the NAS password and I have access to my files etc. If I move fmserver to the very top, it will show me the fmserver login (via browser public IP) instead and block my NAS access. I'd like both of them to be somehow accessible from the outside, I tried putting the Translate to Port Number to 5003 for fmserver but doesn't seem to work.
Also, the Inbound Services have same values as fmserver inside "edit" except for name of service of course and Start IP, but I don't see say Talkswitch used anywhere else as Inbound Services pictures uses ANY for all except fmserver.. so I don't get how this was set up.
I haven't modified anything yet as it seems NAS and phones are working fine together, but NAS and filemaker seem to overlap, wichever one is on top in Inbound services goes through. All other screens on rounter config are empty/defaulted I believe.
Sorry for longetivity of this post, appreciate any help.
- JohnRoApr 27, 2016NETGEAR Employee Retired
Hello sinieq,
Thanks,
- sinieqMay 24, 2016Aspirant
Thank you that fixed the issue :smileyhappy:
