sinieq
Apr 21, 2016Aspirant
Netgear ProSafe VPN Firewall SRXN3205 and port forwarding?
Hi, this is a long shot, but I'm pulling my hairs out at this point and might be a bit over my head as I'm new to networking :( Short story shorter, I have two servers running, one is the NAS box ...
- Apr 27, 2016
Hello sinieq,
There is a heirarchy on the Inbound Services table, this is normal. I see 4 services added using "ANY" (ANY uses any port number) you'll have to remove/disable these because of the heirarchy rule on the table, all other services will be disregarded when ANY is used. What is the port number being used by the NAS? I don't see a port defined for the NAS access. Try disabling services using "ANY" and try again adding translate to port number for the NAS.
Let us know what happens.
Thanks,
JohnRo
Apr 27, 2016NETGEAR Employee Retired
Hello sinieq,
Thanks,
