sinieq
Apr 21, 2016Aspirant
Netgear ProSafe VPN Firewall SRXN3205 and port forwarding?
Hi, this is a long shot, but I'm pulling my hairs out at this point and might be a bit over my head as I'm new to networking :( Short story shorter, I have two servers running, one is the NAS box ...
- Apr 27, 2016
Hello sinieq,
There is a heirarchy on the Inbound Services table, this is normal. I see 4 services added using "ANY" (ANY uses any port number) you'll have to remove/disable these because of the heirarchy rule on the table, all other services will be disregarded when ANY is used. What is the port number being used by the NAS? I don't see a port defined for the NAS access. Try disabling services using "ANY" and try again adding translate to port number for the NAS.
Let us know what happens.
Thanks,
