No_Jah
Feb 05, 2018Aspirant
NoIP for Prosafe routers?
Hi, I'm wondering if it's possible to use NoIP as Dynamic DNS on Prosafe routers? I have a Prosafe SRX5308, and it have four possible DDNS services: DynDNS, DNS TZO, DNS Oray and 3322 DDNS. And...
JohnC_V
Feb 07, 2018NETGEAR Employee Retired
Hi No_Jah,
We can only use the DynDNS as it is the only feature that you may use on this firewall. There is still no plans to this firewalls as NETGEAR already stopped producing the hardware and firmware.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
