srikanthgungi
Nov 03, 2015Aspirant
PORT FORWARDING ON NETGEAR PROSAFE
Hi all,
am trying to open/forward my IP camera system ports in order to have remote access. I have my Camera port numbers in handy but am wondering how to open them.I use Netgear prosafe gigabit dual wan ssl vpn firewall. Hoping to get the help from you guys .Thank you.
Hello srikanthgungi,
Welcome to the community!
To open ports on your firewall you'll have to go to Security>Firewall Rules then click Add (Inbound Services), on the Service drop-down menu are the names of predefined services that you can choose from (see image below for reference):
If the service(s) that you have is not on the list, you'll have to add them manually. Go to Security>Services and Add Custom Service, see image below for reference:
For full instructions, please click on this link (page 230).
I hope it helps, if you have more questions we'll be happy to help.
Thanks,
- JohnRoNETGEAR Employee Retired
Thanks,
- srikanthgungiAspirant
Hi JohnRo,
Thanks for your help, I was trying to open the ports of my IP cameras so that i can have a remote access from my home.So is there any particular service for that sort of ports from the drop down menu that we get under services. and also i have tried by creating a service and making inbound rules which allows always and it was sucessfull but when i check wether the ports are open are not with the following link
http://www.yougetsignal.com/tools/open-ports/
which says that the particular port is closed. Help me with this issue.
Thank You
Hi srikanthgungi,
What ports do you need to open? Post a screenshot of an inbound rule that you have created so I can check if it's done properly. Also, what is the model/brand of your modem?
Looking forward to your response.
Thanks,
