rutsagig
Apr 17, 2017Aspirant
PPTP VPN connect but cannot ping
Regards. I have a NETGEAR ProSafe™ Gigabit Quad WAN SSL VPN Firewall SRX5308 in this LAN: Network: 192.168.1.0/24 Firewall IP: 192.168.1.1 PPTP Server IP subnet: 192.168.25.0/24 I configur...
- May 18, 2017
Sorry for the delay.
Finally I told my clients to leave "Default gateway in remote network" checked, warning them that they will lose internet while connected to the VPN.
It's a shame that the firewall force you to give the VPN a different subnet than the LAN.
Regards.
DaneA
Apr 18, 2017NETGEAR Employee Retired
Hi rutsagig,
Welcome to the community! :)
It seems that your concern is similar on this forum thread. Kindly read it.
What is the current firmware version of the SRX5308?
DaneA
NETGEAR Community Team
- DaneAApr 23, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to read the forum thread I've shared? Also, what is the current firmware version of the SRX5308?
We’d greatly appreciate your feedback.
DaneA
NETGEAR Community Team- rutsagigApr 24, 2017Aspirant
This is the info of my firewall:
System Name: SRX5308
Firmware Version: 4.3.4-2
Secondary Firmware Version: 3.0.7-45
Yes, I have read that forum thread before. It's where I discover I could connect to remote LAN checking "Default gateway in remote network" and using the route command, but as I said this options don't fit my needs.
Is there some way to adding the routes to the firewall?
- DaneAMay 09, 2017NETGEAR Employee Retired
I apologize for this is the only time I got back on this. :(
If ever the PPTP policy is configured correctly, they should be able to connect to the VPN and can get replies when you ping and access the SRX5308 without requiring to add any routes. If it cannot do that, then there is something not right about the PPTP policy.
Here are my follow-up questions:
a. What is the IP range configured on the PPTP Server configuration page?
b. What is the LAN IP range on the PPTP client?
c. Are you using the correct encryption type on the PPTP VPN policy to match what is configured on the SRX5308?
Let me also inform you that firmware v4.3.5-3 has been recently released for the SRX5308. If you wish to upgrade the firmware of the SRX5308, you may download firmware v4.3.5-3 here. Be reminded to perform a factory reset on the SRX5308 after upgrading the firmware then reconfigure it from scratch in order to start clean using the latest firmware version.
DaneA
