jimbo67
Sep 30, 2024Aspirant
PR60X Managing hosts file
Hello, for some reasons i would need to update the hosts file of the touteur ( cannot access lan website using names and ssl with wireguard since i left cloudflare for a cheaper solution ). But ...
c3po2
Sep 30, 2024Apprentice
Thank you for detailed description, we will try to setup same network as yours to see if we can make improvements for your application.
jimbo67
Oct 08, 2024Aspirant
I modified the /etc/hosts file to match my domainename.eu on the server i use as the dns proxy running for local.
Than forced the router to use it to enjoy the loopback ability of the router.
It works fine using this setup but still not while using the vpn.
Only solution yet is to use cloudflare dns proxies to acess those domain with the vpn.
Well i'm not trying anymore to make the vpn work to access my domainname using my sertigo ssl on my services localy hosted.
