FHo
Apr 22, 2016Aspirant
Problem ubuntu Client - openVPN - SSL VPN connecting to proSafe / FSV318
Hi, I want to set up a Simple SSL VPN tunnel. One Linux client - connecting to the FVS318N. The web-SSL is not suitable for me, because the java applet uses root access, but I normally do not...
- Retired_MemberApr 22, 2016
Hi FHo,
You should probably use IPSec VPN.
https://help.ubuntu.com/community/IPSecHowTo
Hope this helps ;)
Retired_Member
Apr 22, 2016Hi FHo,
Hope this helps ;)
- FHoApr 30, 2016Aspirant
Actually - the best was to take IPsec with shrew Soft VPN
