DrCLee
Aug 16, 2019Aspirant
prosafe fvs 318 and 338 compatibility
Hi all i have 2 locations with VPN connection via fvs 338. i have intermittent drop outs on 1 location being serviced with fiber and the service provider wants to isolate the problem as there is an ...
- Aug 21, 2019
Hi DrCLee,
Welcome to our community! :)
It would be possible if you will just replicate the configuration from the 338 going to the 318 from scratch. I suggest, take screenshots of the configuration for you to have a copy and apply it to the other firewall. We cannot back up the configuration and upload it to the other device as they have different firmware and hardware version.
JohnCarloV
NETGEAR Community Team
JohnC_V
Aug 21, 2019NETGEAR Employee Retired
Hi DrCLee,
JohnCarloV
- DrCLeeAug 28, 2019AspirantThank you so much for your help
Will give it a go
Chris
