joelphilippage
Oct 13, 2016Aspirant
NETGEAR ProSAFE Compatible Fiber
Hi,
I have recently purchased two ProSAFE Smart Switches with fiber ports. They are located across campus over 400 ft away and am planning on installing another over 600ft away. I would like to run some outdoor fiber cable to connect them. I have been looking at some products and would like to know what would be compatible.
I was looking at this cable,
with these connectors
Would this be compatable with my system? Am I missing anything? I have never wired fiber before, so would like some advice on what to purchase.
Would appreciate any advice. Thank you!
-Joel
Hello joelphilippage,
Welcome to the community!
I have checked both models, GS716Tv3 and GS748Tv5. The two models support the AGM731F module for multimode. It should work fine along with your cable. If you need more information please go to the datasheet of the switches below:
Let us know if you have more questions.
Thanks,
- JohnRoNETGEAR Employee Retired
Thanks,
Hi joelphilippage,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
