joelphilippage
Oct 13, 2016Aspirant
NETGEAR ProSAFE Compatible Fiber
Hi, I have recently purchased two ProSAFE Smart Switches with fiber ports. They are located across campus over 400 ft away and am planning on installing another over 600ft away. I would like to r...
- Oct 13, 2016
Hello joelphilippage,
Welcome to the community!
I have checked both models, GS716Tv3 and GS748Tv5. The two models support the AGM731F module for multimode. It should work fine along with your cable. If you need more information please go to the datasheet of the switches below:
Let us know if you have more questions.
Thanks,
JohnRo
Oct 13, 2016NETGEAR Employee Retired
Thanks,
