DrCLee
Aug 16, 2019Aspirant
prosafe fvs 318 and 338 compatibility
Hi all i have 2 locations with VPN connection via fvs 338. i have intermittent drop outs on 1 location being serviced with fiber and the service provider wants to isolate the problem as there is an ...
- Aug 21, 2019
Hi DrCLee,
Welcome to our community! :)
It would be possible if you will just replicate the configuration from the 338 going to the 318 from scratch. I suggest, take screenshots of the configuration for you to have a copy and apply it to the other firewall. We cannot back up the configuration and upload it to the other device as they have different firmware and hardware version.
JohnCarloV
NETGEAR Community Team
Nodism1125
Aug 29, 2019NETGEAR Expert
Hi DrClee,
Check IPsec VPN logs under Monitoring > VPN logs. This will help you to understand the intermittent issue.
You can setup VPN IPsec to FVS318 firewall router but the GUI is difference from FVS338. Check the FVS338 configuration first to see if possible to setup using the FVS318 firewall router.
