SatcomGlobal's avatar
SatcomGlobal
Prosafe FVS318GV2
Hoping someone can assist with an issue I am having with a Prosave VPN firewall. For LAN TO WAN traffic I have some rules that allow traffic to specific destinations to a specific port. The Default Outbound policy is set to Block Always. I have just ran a netflow on and I can see traffic been allowed from the lan to dst port: 6002. My question is how is this traffic passing when I have the default outbound policy in place. The only way to stop the traffic seems to have to write a rule always blocking traffic with dst port 6000-6020.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi SatcomGlobal,
    Welcome to the community! :)
    As far as I have checked, there is no issue logged for the FVS318Gv2 as per described in your initial post.  Let us isolate the problem. Kindly answer the questions below:
    a. How did you ran the netflow test?
    b. Kindly try to change the Default Outbound Policy to Allow Always then click Apply.  Then, change again the Default Outbound Policy to Block Always then click Apply.  Does same problem occur?
    c. What is the current firmware version of the FVS318Gv2?  If ever its not yet the latest version, I suggest you to upgrade the firmware to v4.3.5-3. You can download it here.  Be reminded to perform a factory reset on the FVS318Gv2 after upgrading the firmware then reconfigure the setting from scratch to start clean using the latest firmware version.
    DaneA
    NETGEAR Community Team
    • DaneA's avatar
      DaneA
      SatcomGlobal,
      I just want to follow-up on this.  We’d greatly appreciate your feedback.
      DaneA
    • SatcomGlobal's avatar
      SatcomGlobal
      Hi DanaA
      For the Netflow I used Solarwinds.
      I have also changed the default outbound policy and when checking the logs i can see the traffic going through.
      The firmware version on the firewall is currently 4.3.1-9. Could this be the reason for the traffic passing?
ProSupport for Business
