djbetterly
Nov 13, 2015Aspirant
Prosafe FVS336G with two subnets - Need VPN Access
I'll get to the point. We have a VPN firewall, three public IP's and two subnets. I'm trying to get VPN access through to the server which is on a DMZ port. The router has VPN passthrough, and in ...
adit
Nov 14, 2015Mentor
What does the server(s) do?
Why is the server in the DMZ?
Which 336G (v1/v2/v3) and which firmware?
What are the LAN/DMZ subnets and masks?
Which ports did you open?
VPN Passthrough has nothing to do with Inbound VPN.
djbetterly
Nov 15, 2015Aspirant
The server is used as an imaging archive and processing server and needs to be accessible remotely 24/7.
Who ever setup the network initially set the local network up on one subnet, and the server on a DMZ subnet.
The firewall is v2, running the firmware version 3.0.7-24
LAN Subnet - 10.0.1.1/255.255.255.0
DMZ Subnet - 10.0.2.1/255.255.255.0
I initially had opened port 1701 for L2tp access to the DMZ subnet. The server we are trying to get VPN to also has a static IP.
Other info: They have three public IP's, one for a quickbooks server, one for the imaging server and one for an online imaging server. They have asked me to merge all those services into one server. Two of the servers are incredibly old could kick at any point so they want them moved before anything happens.
I'll be honest, I have basic networking experience, but when dealing with two separate subnets it gets a bit tricky for me. Unfortunatly my employer is too cheap to hire a professional to set this up properly. I appreciate your help and patience walking me through this...if you can!
- aditNov 17, 2015Mentor
What are the remotes using to VPN into the server?
Did this work before, and if so, what changed?
- djbetterlyNov 18, 2015Aspirant
The remote machines are running OS X and just use the built in VPN client. VPN access has never been setup with this system.
- aditNov 19, 2015Mentor
Don't think it will work with the built in client. IIRC it would only work with Cisco VPN's.
I think that only VPN Tracker and IPSecuritas(free) worked in the past for OSX.
