djbetterly
Nov 13, 2015Aspirant
Prosafe FVS336G with two subnets - Need VPN Access
I'll get to the point. We have a VPN firewall, three public IP's and two subnets. I'm trying to get VPN access through to the server which is on a DMZ port. The router has VPN passthrough, and in ...
djbetterly
Nov 15, 2015Aspirant
The server is used as an imaging archive and processing server and needs to be accessible remotely 24/7.
Who ever setup the network initially set the local network up on one subnet, and the server on a DMZ subnet.
The firewall is v2, running the firmware version 3.0.7-24
LAN Subnet - 10.0.1.1/255.255.255.0
DMZ Subnet - 10.0.2.1/255.255.255.0
I initially had opened port 1701 for L2tp access to the DMZ subnet. The server we are trying to get VPN to also has a static IP.
Other info: They have three public IP's, one for a quickbooks server, one for the imaging server and one for an online imaging server. They have asked me to merge all those services into one server. Two of the servers are incredibly old could kick at any point so they want them moved before anything happens.
I'll be honest, I have basic networking experience, but when dealing with two separate subnets it gets a bit tricky for me. Unfortunatly my employer is too cheap to hire a professional to set this up properly. I appreciate your help and patience walking me through this...if you can!
adit
Nov 17, 2015Mentor
What are the remotes using to VPN into the server?
Did this work before, and if so, what changed?
