clearform
Oct 07, 2016Aspirant
ProSAFE VPN Firewall Series compatibility with WNDR3800 AP
can a WNDR3800 router configured in AP mode connect with any ProSage VPN firewall
- Oct 10, 2016
Hi clearform,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
JohnRo
Oct 07, 2016NETGEAR Employee Retired
Hello clearform,
Welcome to the community!
Yes, it should work fine. Make sure to get the correct network details from the ProSafe VPN firewall as this will be used to configure the WNDR3800 as AP.
Let me know if you have more questions.
Thanks,
