thompsoncm
Apr 12, 2017Aspirant
QOS with VPN
My ipad /IPhone connects via VPN with no problem and has done for a year or more. Now I enable QOS to give priority to the IPTV box and as soon as a VPN connection is started the whole network go...
DaneA
Apr 19, 2017NETGEAR Employee Retired
If you try to disable the QoS, does it allow the VPN to work again without any issues? If yes, (wherein the VPN works fine without QoS Settings) its possible that it could be some corruption in the config file. I suggest you the steps below:
1. Backup the current configuration.
2. Factory reset the FVS318Gv2.
3. Reconfigure the FVS318Gv2 from scratch.
4. Observe if same problem occurs after setting it up from scratch.
Let us know the results.
DaneA
NETGEAR Community Team
DaneA
Apr 23, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to try the steps I've suggested? If yes, what are your observations?
DaneA
- thompsoncmApr 23, 2017Aspirant
Hi,
Sorry for the delay it took me a while to get the ppoe settings again.
I tried as you sugested but the same problem exists. Without qos set everthing works ok including the vpn connection.
If I enable qos everthings still works ok, until I connect via the vpn from my ipad/iphone then it all fails and I have to pull the power plug to restore the system.
Chris.
- DaneAMay 01, 2017NETGEAR Employee Retired
I suggest you to kindly update the firmware of the FVS318Gv2 to the latest version 4.3.5-3. Be sure to perform a factory reset after upgrading the firmware then reconfigure it from scratch in order to start clean using the latest firmware version. Then check if same problem occurs.
You may download firmware version 4.3.5-3 here.
DaneA
- thompsoncmMay 09, 2017Aspirant
Hi,
I have just tried that but still the same problem. I have also noticed thet also if I enable bandwidth profiles I get the same problem. I loose WAN connection and cannot access the router web login without power off and on.
Chris.
