kallol's avatar
kallol
Follower
Sep 16, 2019
br500 how to setup client authentication with openvpn or regenerate configuration file
Is there anyway to setup per client authentication with openvpn. Openvpn works out of box, both on windows and linux. Have not tried on Mac yet.  The issue is that if an employee leaves, we need to b...
  • MrJoshW's avatar
    MrJoshW
    Jan 08, 2020
    BR500 does not support client authentication based OpenVPN. Currently we support the ability to import the certificate that is generated from the BR500 to the OpenVPN client currently.
ProSupport for Business
