deroliver
Jun 03, 2019Tutor
NETGEAR Insight VPN macOS 10.14.5
I just installed my new BR500 and added a new vpn user. Unfortunately I cannot get the InsightVPNClient to run on my macbook pro running macos 10.14.5. It just crashes everytime I open the app. How c...
MrJoshW
Sep 10, 2019NETGEAR Employee Retired
GOOD NEWS EVERYONE! I have obtained the debug build. If anyone who is experiencing the crashing and issue would like to test the debug build please send me a private message and please provide feedback.
- OlivierBartSep 10, 2019Aspirant
Great !! I can't test for the moment but i'm interesting to know the result. Thx.
- broce381Sep 20, 2019Aspirant
As you are asking for a reliable VPN for watching Apple TV then I would recommend VyprVPN. It is known as a veteran provider that has compressed the geographic limitations on content from Netflix, Hulu, and other famous streaming channels. It’s also an excellent option for users who live in China and who want to bypass the Great Firewall. Go for https://vpn.review/apple-tv-vpn-setup/ to find out more about VPN set up. This VPN is not only supple, it’s also a strong performer, and has high-end encryption and fast download speeds.
The corporation functions VyprDNS, its own private and encrypted DNS service, which helps in unblocking and keeping your browsing habits secure. It has been tested that it works perfectly fine for Apple TV. To set it up on DNS Proxy go for the Main menu, tap Settings > Network. Detect your present network and choose Configure DNS > Manual. Now add the DNS address from MediaStreamer or whatsoever DNS provider you’re utilizing. It should be a cord of numbers and decimals, pick the option says Done before resuming Apple TV.
- jkupeSep 10, 2019Aspirant
Great news! PM sent!
- OlivierBartSep 12, 2019Aspirant
Hello, do you have test the patch ? thx
- OlivierBartSep 25, 2019Aspirant
Some news about this bug with Mac Pro ?
- MrJoshWSep 25, 2019NETGEAR Employee Retired
Engineering believes the issue is with MacOS and webview. They are currently working on a test build with a webview fix. Once I hear feedback from them I will report any updates.
- OlivierBartSep 26, 2019Aspirant
Thx a lot
