centex-rj
Aug 31, 2015Aspirant
Netgear Prosafe FVS-336G (fvs336g-200eus) - Slow througput
Hi Have a fvs336g-200eus, and LAN to WAN thoughout is about 25-30mbit. Datasheet says 350mbit? What do i do wrong? Upgraded to newest firmware, with not result. Reset to default, with no result. ...
- Sep 07, 2015
Hi centex-rj,
I have read again your initial post and since you mentioned that you have a FVS336G-200EUS, what you have is an FVS336Gv2 not an FVS336Gv3. The LAN-to-WAN Throughput of the FVS336Gv2 is 60 Mbps while the LAN-to-WAN Throughput of the FVS336Gv3 is 350 Mbps. Kindly check these links below as reference:
http://www.downloads.netgear.com/files/GDC/datasheet/en/FVS336Gv2.pdf
http://www.downloads.netgear.com/files/GDC/datasheet/en/FVS318G-FVS318N-FVS336G-SRX5308.pdf
centex-rj wrote:
A: Fiber (ISP Converted to RJ45 with a calistobox, and then through a cisco router)
B: It is connected to a Cisco ASA5505 as this router is used for administrative-net, and wifi. The Netgear router is being used as a guest wifi DHCP/Gateway, and is connected to the Cisco ASA. But if i connect a PC directly to the Cisco ASA there are full power (100mbit WAN)
C: Yes, WAN2 is same slow speed.
D: 4.3.3-5
Block TCP flood, is disabled - no increese. Also bandwith profile og content filtering are disabled as well.
Alsp tryed change it to "Classic routing" istead of "NAT" that gave about 1-2mbit, but
Based from you answers above, you have a scenario called "Double NAT" and this is why you are getting 25-30Mbps of LAN-to-WAN throughput through the FVS336Gv2. Kindly try to make the FVS336Gv2 your main firewall router not the Cisco ASA5505 then observe if you will get at least 60Mbps of LAN-to-WAN throughput through the FVS336Gv2.
DaneA
Netgear Community Team
DaneA
Sep 07, 2015NETGEAR Employee Retired
Hi centex-rj,
D: 4.3.3-5
DaneA
centex-rj
Sep 07, 2015Aspirant
Okay - but still. 25-30mbit is half the rated speed.
- DaneASep 07, 2015NETGEAR Employee Retired
Hi centex-rj,
As I have mentioned, you have a scenario called "Double NAT" and this is why you are getting 25-30Mbps of LAN-to-WAN throughput through the FVS336Gv2. Check this link below and read about Double NAT:
http://kb.netgear.com/app/answers/detail/a_id/992/~/what-is-nat-(network-address-translation)%3F
To isolate the problem, kindly remove the Cisco ASA5505 for the meantime and make the FVS336Gv2 your main firewall router. Observe if you will get at least 60Mbps of LAN-to-WAN throughput through the FVS336Gv2.
You may contact Netgear Support and they could assist you over the phone to setup the FVS336Gv2 and you can also raise your concerns about it: http://support.netgear.com/general/contact/
DaneA
- SamirDOct 05, 2015Prodigy
Wait, is this on wifi or via the wired lan connections? 25-30 via wifi is about right.
