Subdivisions
Jan 16, 2017Aspirant
SRX5308 Box to Box VPN Connecting but no data passes through.
I have 2 SRX5308's in 2 office locations. Im trying to connect them together via a box to box vpn so the phone vendor can use that connection to pass remote IP phone line and office data to the remo...
- Jan 17, 2017
Hi Subdivisions
Can you try to change the start ip from 192.168.0.254 to 192.168.0.0?then have atry?
Regards
ChenX
Jan 17, 2017NETGEAR Expert
Hi Subdivisions
Regards
Subdivisions
Jan 23, 2017Aspirant
Is this on the box thats at the source location im taking? Im making the change now and testing.
- SubdivisionsJan 23, 2017Aspirant
This worked, I now can browse network shares from one office to the other. Thanks so much for the solution!
- ChenXJan 23, 2017NETGEAR Expert
Hi Subdivisions
I am glad to hear it works and we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards
