sabre_tooth
Oct 04, 2017Follower
replacing Fvs336GV2 with SRX5308 - configuration issues
I purchased an SRX5308 Firewall to replace my FVS336GV2 so I can process faster internet speeds. I thought I had correctly configured it and it was running well for about 23 or 24 hours. All of a s...
JohnC_V
Oct 09, 2017NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. Just in case that the reply was the solution to your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
