tnooc
Apr 09, 2017Aspirant
Slow network performance when connecting to RAS
I replaced an older 318 with a FBS318v2 and the internal network is working great, and a problem I had with dropped internet appears to be solved. I have a remote access server (RAS) set up on the i...
DaneA
Apr 12, 2017NETGEAR Employee Retired
Hi tnooc,
Welcome to the community! :)
Kindly answer the questions below:
a. If you try to disable the firewall rule, does same problem occur?
b. When you have updated the firmware of the FVS318Gv2 to the latest version, did you perform a factory reset after the firmware upgrade?
c. Is the RAS directly connected to the FVS318Gv2? Kindly post a diagram of your detailed network setup.
DaneA
NETGEAR Community Team
- DaneAApr 17, 2017NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
DaneA
- tnoocApr 17, 2017Aspirant
Sorry for the slow response. To anwser your questions:
1. If you disable the firewall rule there is no affect on network traffic, and of course the connection to RAS doesn't happen.
2. We did not reset the router after installing the updated firmware.
3. I don't have any software to diagram the network, but there is a switch between the Netgear Router and the RAS Server. We have tried plugging the RAS directly into the router (the router is the gateway for the network) and it does not improve the performance. The only hardware change in the network is the change from and FVS318v3 to the FVS318Gv2.
