Cody784
Jul 26, 2019Aspirant
Speed capped at 9.0mbps instead of full 25mnps
I have my router for less security. the repeter is connected to it. with prosafe FVS318v3 behind it for a nat 3 network for security l. the firewall is not reaching 25 mbps like the others. its capped to 9mbps. the upload is good however. Is there a way I can configure it to match the speed of the rest of the network?
Welcome to the community! :)
The LAN-to-WAN (or WAN-to-LAN) Throughput of the FVS318v3 is only 11.5Mbps. As reference, kindly check the FVS318v3 Data Sheet here.
If your subscription with your ISP (Internet Service Provider) is 25 Mbps, you will need a firewall router that has a WAN-to-LAN Throughput that is higher than 25Mbps. You may want to check the BR500 that has a LAN-to-WAN Throughput of 924Mbps. For more information about the BR500, kindly check its data sheet here.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Regards,DaneA
- Cody784AspirantIs there a simalar firewall with roughly the same ui as the prosafe in can get for 25 mbps
The ProSAFE VPN Firewall Series of NETGEAR was already EoL (End-of-Life). Kindly check the announcement here. The VPN Firewall Series includes the FVS318Gv2, FVS318N, FVS336Gv3 and SRX5308. For the respective LAN-to-WAN Throughput of these VPN firewalls, kindly check the data sheet here.
Be reminded that since these VPN firewalls are already EoL, there would be no new fixes and new firmware releases.
DaneA
