Dimitri1
Aug 04, 2017Aspirant
SRX 5308 secondary wan address on vlan
Hi, We are using the SRX 5308 with firmware version 4.3.1-22. We have one WAN configured with an secondary address. On the LAN side we use multiple vlan's. What i want is that one vlan uses the sec...
- Aug 07, 2017
Thanks for your reply,...
I do not have WAN2 physical connected. The secondary address is one configured on WAN1.
For now i have configured an outbound rule that any port comming from the vlan address scope has to go trough the secondary address.
Any inbound rule i can configure to.
Gr,
Dimitri
Dimitri1
Aug 07, 2017Aspirant
Gr,
Dimitri
JohnC_V
Aug 08, 2017NETGEAR Employee Retired
It would be the same even if you are not using it on the WAN2. You will also see the secondary IP addresses that you entered on the same page. Inbound Rules/Port forwarding is only used if you wanted to have some ports to be open on the public network. So no need to create any inbound rules anymore unless you also wanted it to pass-through on the secondary address.
