juerg
Aug 15, 2015Aspirant
SRX 5308 Firmware upgrade gone bad
After rebboot, the system doesn't work anymore. The test light is on an the console prompts: srx5308 bootloader:
Does anyone knows the commands for the bootloader?
How can I switch to the secondary firmware.
Juerg
Hi
Yes the problem was solved by a new system. I got a replacement for free by Netgear. They told me it is the only way to solve this problem.
Juerg
- JohnRoNETGEAR Employee Retired
Hi juerg,
Welcome to the community!
Upon checking your case on our system, it shows that the Next Business day replacement is on its way.
Have a great day!
Thanks,
- juergAspirant
Hi
Juerg
Hi juerg,
It shows that the router got bricked, an RMA is neccessary since it requires enginerring to issue the bootload command. I hope the replacement router will serve you for a long time.
Thanks,
