AlexMILL
Jul 10, 2015Follower
SRX5308 and DHCP relay
HI, I have a SRX5308 and I would like to configure LAN1 with subnet 192.168.4.1/24(less 192.168.4.1 to 192.168.4.10) and LAN2 with 192.168.5.1/24. The DHCP is a Windows Server 2012 and it is connect...
JohnRo
Jul 30, 2015NETGEAR Employee Retired
Hi AlexMILL,
Welcome to the community! You can assign and manage VLAN profiles along with VLAN DHCP options on Network Configuration>LAN Settings>LAN Setup. Please see image below for reference:
You can find the description of each options on this link, please check pages 86 to 88.
Hope this helps! I'll look forward to your response.
Thanks,
- May 22, 2011Anonymous
